After wiring some of the KFlop I/O to a relay board, I find the I/O is initially unstable when power is connected to KFlop. What is interesting is that one to two outputs are toggled but others are not.
Is there a way to prevent the I/O from toggling at random during boot? The relays are driving motors and coolant so this could create a problem unless another relay is used to manually energise the motors after boot.
Group: DynoMotion
Message: 12050
Date: 8/1/2015
Subject: Re: I/O Unstable during boot
Hi Eon,
Not sure exactly what you are referring to but Bits 16-20 and 23 on JP4 are momentarily driven to auto detect the presence of a SnapAmp and Bits 12,13, and 15 on JP7 are momentarily driven to auto detect the presence of a Kanalog. That might be what you are seeing. If that causes a problem then as you describe another relay or I/O might be needed to keep things disabled until after the boot has completed.
Group: DynoMotion
Message: 12052
Date: 8/2/2015
Thanks Tom
Yes, this is what is happening. It is a pity this cannot be disabled somewhere – the checking is only needed when configuring the system initially and then never again as the configuration for a specific machine is unlikely to change and if so, needs to be configured again.
Eon
From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] Sent: Sunday, 02 August 2015 00:38 To: DynoMotion@yahoogroups.com Subject: Re: [DynoMotion] I/O Unstable during boot
Hi Eon,
Group: DynoMotion
Message: 12055
Date: 8/2/2015
Attachments :
Hi Eon,
Well that sort of defeats the purpose of auto detection but I could see how that could be a problem. Here is a Version 4.33o that allows disabling the autodetection.
http://dynomotion/Software/KMotion433o.exe
After upgrading run the attached program to set the disable autodetection flags:
Then Flash User Data. The Autodetection will be disabled on the next boot. You will need to remember to do this whenever a new Firmware is loaded, boards swapped, or configuration changes.
Group: DynoMotion
Message: 12069
Date: 8/6/2015
Hi Tom
For some reason I am not able to download the version 433o but I can download the other versions. What could be the reason?
Eon
From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] Sent: Sunday, 02 August 2015 21:32 To: DynoMotion@yahoogroups.com Subject: Re: [DynoMotion] I/O Unstable during boot
Hi Eon,
Group: DynoMotion
Message: 12071
Date: 8/6/2015
Hi Eon,
Please try this link to download KMotion433o.exe from Google Drive. The .exe
has already been scanned for viruses prior to uploading so you can
ignore Google Drive's warning that it could not scan due to the file
size limitations.
